NAND FLASH的调用 作者:david   发表日期:2020-09-14   来源:   浏览:
RA8889,RA8876,RA8877,RA8873及RAA8871系列控制器 内建 SPI master 接口,此功能主要使为了使用外部闪存/ROM,支持的协议有 4-BUS (Normal Read)5-BUS (FAST Read)Dual mode 0Dual mode 1 Mode 0/Mode 3
外部串行flash我们支持市面上大部分的NOR FLASH,若客户需要用到大容量NAND FLASH,我们的芯片支持华邦的W25N01GYZEIT,更换为NAND FLASH后DMA的调用则与NOR FLASH有点不同,操作如下:
需要将flash中的图片先调到显存中,再用BTE搬用显示,
调取函数如下
void SPI_NAND_DMA (unsigned long dma_page_addr,unsigned long X_coordinate,unsigned long Y_coordinate,unsigned int picture_Width,unsigned int picture_Height,unsigned long pic_buffer_Layer,unsigned long Show_pic_Layer,unsigned char chorma,unsigned long Background_color)
#ifdef MCU_8bit_ColorDepth_8bpp
  Background_color_256(Background_color);
#ifdef MCU_8bit_ColorDepth_16bpp
  Background_color_65k(Background_color);
#ifdef MCU_8bit_ColorDepth_24bpp
  Background_color_16M(Background_color);
#ifdef MCU_16bit_ColorDepth_16bpp
#ifdef MCU_16bit_ColorDepth_24bpp_Mode_1
#ifdef MCU_16bit_ColorDepth_24bpp_Mode_2
nSS_Active();
SPI_Master_FIFO_Data_Put(0x13); //page data read(13h)
SPI_Master_FIFO_Data_Put(0x00); //8Dummy clock
SPI_Master_FIFO_Data_Put((dma_page_addr)>>8);   //page address MSB
SPI_Master_FIFO_Data_Put(dma_page_addr);   //page address LSB
nSS_Inactive();
delay_us(50); //delay for buffer load
Memory_Linear_Mode();
SFI_DMA_Source_Start_Address(dma_page_addr);//24bit address
#if defined  MCU_8bit_ColorDepth_8bpp
SFI_DMA_Transfer_Number(picture_Width*picture_Height);//picture Width x Height x Color depth(8/8=1)
#if defined  MCU_8bit_ColorDepth_16bpp
SFI_DMA_Transfer_Number(picture_Width*picture_Height*2);//picture Width x Height x Color depth(16/8=2)
#if defined  MCU_16bit_ColorDepth_16bpp
#if defined  MCU_8bit_ColorDepth_24bpp
SFI_DMA_Transfer_Number(picture_Width*picture_Height*3);//picture Width x Height x Color depth(24/8=3)
#if defined  MCU_16bit_ColorDepth_24bpp_Mode_1
#if defined  MCU_16bit_ColorDepth_24bpp_Mode_2
SFI_DMA_Destination_Start_Address(pic_buffer_Layer);//DMA to Memory Address 1280*480*3
Start_SFI_DMA();
Check_2D_Busy();
  BTE_S0_Color_24bpp();
  BTE_S0_Memory_Start_Address(pic_buffer_Layer); //S0 Address 1280*480*3
  BTE_S0_Image_Width(picture_Width);
  BTE_S0_Window_Start_XY(0,0);
  BTE_Destination_Color_24bpp();
  BTE_Destination_Memory_Start_Address(Show_pic_Layer);
  BTE_Destination_Image_Width(canvus_width);
  BTE_Destination_Window_Start_XY(X_coordinate,Y_coordinate);
 if(chorma==0)
  BTE_ROP_Code(12);
  BTE_Operation_Code(0x02);
 if(chorma==1)
  BTE_Operation_Code(0x05);
  BTE_Window_Size(picture_Width,picture_Height);
  BTE_Enable();
  Check_BTE_Busy();
  Memory_XY_Mode();
直接将此函数添加进API并调用即可,如果使用本公司提供的开发板且须添加初始化函数SPI_NAND_initial_1 (void)初始化或者SPI_NAND_initial_0 (void)选择CS0还是CS1
void SPI_NAND_initial_1 (void)
SPI_Clock_Period(0);
//  Reset_CPOL();
Set_CPOL();
// Reset_CPHA();
    Set_CPHA();
Select_nSS_drive_on_xnsfcs1();
W25N01_Device_Reset();
W25N01_Clear_BUF();
W25N01_Set_ECC();
//Select_standard_SPI_Mode0_or_Mode3();
Select_RA8875_SPI_Mode0_and_Mode3();
//Select_SFI_Single_Mode_Dummy_0T_03h();
Select_SFI_Single_Mode_Dummy_8T_0Bh();
//Select_SFI_Single_Mode_Dummy_16T_1Bh();
//Select_SFI_Dual_Mode_Dummy_8T_3Bh();
//Select_SFI_Dual_Mode_Dummy_4T_BBh();
Enable_SFlash_SPI();
Select_SFI_1();
Select_SFI_DMA_Mode();
Select_SFI_24bit_Address();
Memory_XY_Mode();
void SPI_NAND_initial_0 (void)
//  Reset_CPOL();
Set_CPOL();
// Reset_CPHA();
    Set_CPHA();
Select_nSS_drive_on_xnsfcs0();
W25N01_Clear_BUF();
W25N01_Set_ECC();
Select_SFI_0();
Memory_XY_Mode();
使用范例:
注意图片放置地址不可超出显存大小,例:分辨率为800*480 、24bpp放置到第二个图层则为800*480*3 即1152000
这里要根据图片实际信息进行设置
相关热词搜索:RA8889,RA8876,RA8875,NAND FLASH
上一篇:RA88xx系列对显存直接读写点的方法
下一篇:关于RA8873M及RA8871M的图层显示
>>延伸阅读:1
  • · RA8889开发板如何通过外部烧录器进行更新FLASH内容 [2022-04-01]
